delete vlan
delete [ {vlan} vlan_name | vlan vlan_list]
Description
Deletes a VLAN.
Syntax Description
vlan_name Specifies a VLAN name.
vlan_list Specifies a VLAN list of IDs.
Default
N/A.
Usage Guidelines
If you delete a VLAN that has untagged port members and you want those ports to be returned to the default VLAN, you must add them back explicitly using the configure svlan delete ports command.
The default VLAN cannot be deleted. Before deleting an ISC VLAN, you must delete the This command is available on all Universal switches supported in this document. peer.
The following command deletes the VLAN accounting:
delete accounting
The vlan_list option was added in ExtremeXOS 16.1.
Platform Availability
